Bore to piston gap?
fluff34567
Does anyone have the piston to bore gap tolerance for a tv175? Still waiting for my manual to arrive and like to get some bits ordered if needed.
Thanks in advance
bazza3004
Iirc its around 4thou on a cast barrel
Lamaddict
I thought Innocenti made them tighter than that. My Standard TV175 flys, good luck with yours.
fluff34567
Thanks 4 thou is .1mm my bore varies from 62.020 to 62.040 with a piston diameter ranging from 61.9 to 62mm so should be good.
Grumpy225
I have all my iron cylinders bored to .0035" clearance and plated to .0025"-.003"
Zero problems
bristolmod
Grumpy225 wrote:I have all my iron cylinders bored to .0035" clearance and plated to .0025"-.003"
Zero problems
agree- also subject mine to "short sharp shock" running in. Quick hot/cold cycles.
Chris
Scootering since 1968.
fluff34567
Perfect thanks!
philz
Main scooter: Lambretta Li150
Just had a cast 175 bored to 4 thou. Should it still be run in for 1000 miles as per innocenti advice. Using 4% mix mineral.
    Users browsing this forum: Amazon [Bot], Google [Bot] and 14 guests
