Does anyone have the piston to bore gap tolerance for a tv175? Still waiting for my manual to arrive and like to get some bits ordered if needed.
Thanks in advance
Bore to piston gap?
fluff34567
Iirc its around 4thou on a cast barrel
I thought Innocenti made them tighter than that. My Standard TV175 flys, good luck with yours.
fluff34567
Thanks 4 thou is .1mm my bore varies from 62.020 to 62.040 with a piston diameter ranging from 61.9 to 62mm so should be good.
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
agree- also subject mine to "short sharp shock" running in. Quick hot/cold cycles.Grumpy225 wrote:I have all my iron cylinders bored to .0035" clearance and plated to .0025"-.003"
Zero problems
Scootering since 1968.
fluff34567
Perfect thanks!
