6000 rpm normal????
storkfoot
- registered user
- Main scooter: '70 GP150 [TS1 225]
- Contact:
Please don't take this the wrong way but, if you are messing with tuned Lambretta engines, you really need to buy a strobe and figure out how to use it. They are very straightforward
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
Not taken in the wrong way at all mate - I'm a good student - here to learn. To be honest it's one of the only areas i haven't tried to do myself yetstorkfoot wrote:Please don't take this the wrong way but, if you are messing with tuned Lambretta engines, you really need to buy a strobe and figure out how to use it. They are very straightforward
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
alanscottj
- registered user
- Contact:
Got myself a strobe gun this afternoon so will have a play later and see where the timing is atalanscottj wrote:Not taken in the wrong way at all mate - I'm a good student - here to learn. To be honest it's one of the only areas i haven't tried to do myself yetstorkfoot wrote:Please don't take this the wrong way but, if you are messing with tuned Lambretta engines, you really need to buy a strobe and figure out how to use it. They are very straightforward
alanscottj
- registered user
- Contact:
Yeah, got a stopper that screws into the spark plug and a Cam Lam timing discmick1 wrote:Well done![]()
Remember the strobe is only as accurate as your TDC mark..........and the other marks based on that.
alanscottj
- registered user
- Contact:
Okay - here's one for ya!
Set up the strobe light - started the engine - started to strobe - could clearly see the arrow pointing upwards at dead on 12 o'clock - gave a little throttle - arrow retarded a few degrees, all good I thought, so gave a little bit more throttle and the arrow retarded a touch more (only 7 or 8 degrees) then bam it was gone! Stopped engine - started again perfect - same again, retarded 7 or 8 degrees then it disappeared again, this time I left engine running and found the arrow again - virtually opposite at 6 o'clock!!! So, after about 6000 revs my Varitronic is retarding about 180 degrees!
I'm no expert but I would say that is what is wrong with my engine
What i don't know though is what is causing it???
Any help most appreciated - as always!
Scott
Scott
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
Could be the double spark on the Varitronic causing the strobe to have hic-ups. cam-lam used to sell a strobe suitable for the Varitronic.
Mines a Draper ยฃ20 job that worked fine so who knows if a special one is required.
On the other hand you could be seeing your stator/cdi breaking down
tarmac tickler
- registered user
- Contact:
make another timing mark directley opposite the one on the flywheel,, ie,, if timing mark is 12 oclock, make one at 6 oclock,,, re strobe and as if like magic you,ll see the new timing mark
- drunkmunkey6969
- Moderator
- Contact:
The spark is breaking down under load...possibly due to misalignment between stator pickup and flywheel firing point.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
