6000 rpm normal????
storkfoot
Please don't take this the wrong way but, if you are messing with tuned Lambretta engines, you really need to buy a strobe and figure out how to use it. They are very straightforward :-)
alanscottj
storkfoot wrote:Please don't take this the wrong way but, if you are messing with tuned Lambretta engines, you really need to buy a strobe and figure out how to use it. They are very straightforward :-)
Not taken in the wrong way at all mate - I'm a good student - here to learn. To be honest it's one of the only areas i haven't tried to do myself yet ;)
alanscottj
Got myself a strobe gun this afternoon so will have a play later and see where the timing is at ;)
mick1
Main scooter: Li Avanti 225
Well done :D
Remember the strobe is only as accurate as your TDC mark..........and the other marks based on that.
alanscottj
mick1 wrote:Well done :D
Yeah, got a stopper that screws into the spark plug and a Cam Lam timing disc :D
storkfoot
That's exactly what I have. I have not strobed a Varitronic. I presume they strobe the same?
alanscottj
Okay - here's one for ya!
Set up the strobe light - started the engine - started to strobe - could clearly see the arrow pointing upwards at dead on 12 o'clock - gave a little throttle - arrow retarded a few degrees, all good I thought, so gave a little bit more throttle and the arrow retarded a touch more (only 7 or 8 degrees) then bam it was gone! Stopped engine - started again perfect - same again, retarded 7 or 8 degrees then it disappeared again, this time I left engine running and found the arrow again - virtually opposite at 6 o'clock!!! So, after about 6000 revs my Varitronic is retarding about 180 degrees!
I'm no expert but I would say that is what is wrong with my engine :lol:
What i don't know though is what is causing it???
Any help most appreciated - as always!
Scott
mick1
Could be the double spark on the Varitronic causing the strobe to have hic-ups. cam-lam used to sell a strobe suitable for the Varitronic.
Mines a Draper ยฃ20 job that worked fine so who knows if a special one is required.
On the other hand you could be seeing your stator/cdi breaking down
tarmac tickler
make another timing mark directley opposite the one on the flywheel,, ie,, if timing mark is 12 oclock, make one at 6 oclock,,, re strobe and as if like magic you,ll see the new timing mark
The spark is breaking down under load...possibly due to misalignment between stator pickup and flywheel firing point.
