urgent help required!
Dazza
I took my scoot out tonight , it was running fine - just round the block didn't thrash it at all, i pulled over to faff about with my gps and the engine stopped suddenly and was solid when i tried to kick it, it eventually kicked over but compression was down and it wouldnt start.
pushed the bloody thing home and stripped it down to find the ring/s had snagged on the exhaust port.
The top end is a rapido 225 - i'd like to hear if anyone knows why this could have happened?
I also need to get a new piston and rings tomorrow if possible (i think the barrel has survived) where am i likely to get them from ? I am in Newark,Notts and can travel a reasonable distance to get it - possibly thinking MB?
Any suggestions?
RinB
Ouch m8
Id ring MBs first He may not keep them.
Beedams in Grimsby keep Rapido on stock ring first though
Dazza
Cheers Smithy - will try beedies - i'll have to eat my words after spitting my dummy out with them a while ago :oops:
I've just noticed the piston is an escorts piston - any opinions on these?
paulmgreen
Do you definitely nee dtomorrow? How about Rayspeed and get them to courier it for following day delivery?
www.JPPLambretta.co.uk
Dazza
No Paul I was in panic mode :D
I'm hoping to get it sorted ready for Darlo on Saturday so if I get it delivered Thursday I should be fine.
As Smithy said they have them in beedies - interestingly though they have one listed for £37.99 and an asso for £99.99 - i'll bet any money the 37.99 is an escorts version :evil:
I may not be round for that oil by the way - I might not need it now :cry:
Cheers
rog60
Main scooter: Indian GP200
Dazza wrote:Cheers Smithy - will try beedies - i'll have to eat my words after spitting my dummy out with them a while ago :oops:
My opinion and thoughts:-
Escorts/ Mahle made in India under licence and I understand that Mahle 'took over' Borgo :?:
I believe most Indian GP engines have Mahle copy pistons fitted and while not the best of items they are OK for general road use but not the No 1 choice on a Rapido :!: :!: :!:
Is it the three cast iron ring version?
Pull a sicky dazza and pick em up by hand..you know youve got em them..could try the swine flu angle..nothing worse then an empending run and a playing up scoot..as I was last week..good luck matey..
Dazza
Lam46 wrote:Pull a sicky dazza and pick em up by hand..you know youve got em them..could try the swine flu angle..nothing worse then an empending run and a playing up scoot..as I was last week..good luck matey..
I think I may just do that - no need to pull sicky - i'll just pretend I'm somewhere that I'm not :D
Dazza
No its only a 2 ring jobby - but definately an escorts piston which I think is the culprit :cry:
rog60
I would think that if it has cast rings then definitely yes.
    Users browsing this forum: Semrush [Bot] and 74 guests
