Hi, I`m accumulating parts for an 200cc + engine build and have been reading loads about gear ratios etc etc
I`m not bothered about going much above 70+ just want torque .
If I've already got a late Li150 pacemaker loose gears , but what cluster should I be on the lookout for ??
cheers in advance
Gear Cluster
The one that matches it.
Think the number of teeth are
11
13
17
19
Not sure if this helps you.
11
13
17
19
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
no- you need a Pacemaker cluster 11;13;17;19.nellyboyo wrote:Ha , ok so only an Li150 one then ....
Assuming you've got 50;41;39;35 gears.
Scootering since 1968.
- Information
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 6 guests
