Gear Cluster
nellyboyo
Hi, I`m accumulating parts for an 200cc + engine build and have been reading loads about gear ratios etc etc
I`m not bothered about going much above 70+ just want torque .
If I've already got a late Li150 pacemaker loose gears , but what cluster should I be on the lookout for ??
cheers in advance
Daggs
The one that matches it.
Muppet
Daggs wrote:The one that matches it.
blunt but correct ;)
C’est la vie
bazza3004
Think the number of teeth are
11
13
17
19
Not sure if this helps you.
nellyboyo
Ha , ok so only an Li150 one then ....
bristolmod
nellyboyo wrote:Ha , ok so only an Li150 one then ....
no- you need a Pacemaker cluster 11;13;17;19.
Assuming you've got 50;41;39;35 gears.
Scootering since 1968.
nellyboyo
Yes sorry , I meant LI150 pacemaker ....god knows where I`ll get one of them then .....
