TV175 1963 strip and rebuild
fluff34567
I have a few possibilities on a replacement crank so no worries there.
On a more positive note I have arranged access to a blaster on a DIY basis.. a small one which the frame can go in and maybe a walk in also. It uses fruit stone.. I guess they mean walnut, I tried the air box as a test piece and the paint fell off.
I'm making my list of required parts and Cambridge appears to be a 1 stop shop but has high postage.. will need to sit down and compare totals.
garry inglis
Try mike at Torbay lambretta excellent service
Timbo
garry inglis wrote:Try mike at Torbay lambretta excellent service
.....plus he refunds postage if he initially quotes more..
dave411
Main scooter: Li 125
Yes,top guy.Really good,fast service.Very reasonable carriage charges too.
fluff34567
Yep looked at his site earlier have to tick off what he has available.
fluff34567
I am on holiday so no updates for a while but whilst I am away the engine casing and various ofter parts on the frame are being welded.
As I don't have access and couldn't find the info online can someone tell me the bolt size for the stand mounting bolts please, Is it M8?
Thanks in advance.
fluff34567
Received a pic from the welder. . Engine case is done and looks good.Image
It does look good. Mind you I can't even tell where it was repaired. Was it the linished bit?
fluff34567
Yep exactly, I will blast it next week and should look perfect without any hint of a repair.
I'm pulling in a few contacts to get them clear anodised or acid dipped so end result should be quite nice.
fluff34567
Just saw the casing damage caused by a loose rim bolt isn't here and will further explain the above pic.
Yes the rim mounting bolts will be replaced Image
    Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
