TS1 225 Kits - advice please
gaz_powell
I've used 4.8 from day one with a fresco and it still suits me perfect (Indian gp 200 with 19/46), the frescos gone (to back of garage) and replaced with a taffspeed copy on my standard 225 (other than MB manifold) - i'm 10 stone and never ride 2 up.
Same set up on my all my bikes.
Works well overall on all roads types, good on banks and against wind.
Strummer10
Cheers again Adam and Gaz / others...........
i'll have a dig around to see what I have in the garage and next steps.....fortunately i'm only 10 and a half stone and don't ride two up so less for the scooter to deal with lol....
Adam, Must confess I did contemplate sticking the Dave Webster stage 4 iron barrel back on the bike, but after cleaning off the scorch marks on the piston and cleaning the barrel I inadvertently broke one of the rings, which In turn allowed me to stop and think whilst apart about shall I 'kit it up' OH and the top piston ring had also 'gummed itself into the top groove' .....but it was tons of fun to ride and quick ............................................
I could keep it going, but must confess, with the intention of using the bike for Europe in 2017 it probably makes sense to go the nicasil route..........
gaz_powell
Been an interesting thread this and glad I could contribute.
The OP question was about heads - I ve used a couple of the AF ready done 225 TS1 8:1 with success, they are decent and excellent value, before these I used to get genuine SIL ones modified (still run 3 TS1 motors with SIL heads with no issue).
AF now pushing their Avanti esq Mammouth heads for 2017....something else to consider!!
Gaz
Strummer10
Cheers Gaz and all..........
Must confess I use a lot of SIL components without any issues.........including stators and cranks and have had no concerns personally.
yes I heard AF were releasing their version of the Avanti cylinder head (just goes to prove the usefulness of enlarged cooling fins I guess) so I guess operational temperatures will have been reduced by it........
Presumably the original Avanti 225 head also fits the TS1 .
garry inglis
iam having the same problem deciding what to go for with the ts1 i have anew ads5 road race a franspeed super tourer a tamini full circle 58x107 race crank from jb tunning so buying ts kit with head is £460 a new 30mm vhsh £200 thats only £660 and iam up and running so a cheap kit for me i no ive paid for the other bits but we all collect spairs for whatever reason i am fitting li150 at 46x16=4.9
"Presumably the original Avanti 225 head also fits the TS1 .", not a straight fit, no. The Avanti head is machined to have a spigot that locates into the barrel so the barrel is manufactured longer to suit, whereas the TS1 has a head that sits flat against the top of the barrel (no spigot on head). AF have copied Ron's design and then simply changed how it is machined. They used to buy blanks from Ron and machine them to their purposes but realised that they could copy Ron's work and get it made cheaper elsewhere.
hendy
I bought an avanti head from Ron Moss last year for my ts1 225.
He makes more than one type. Also does small block I believe.
holty
Main scooter: lambretta gp
heres a pic of rayspeeds new head, its got extra fins and slots underneath and wont fit an avanti
Adam_Winstone wrote: The Avanti head is machined to have a spigot that locates into the barrel so the barrel is manufactured longer to suit, whereas the TS1 has a head that sits flat against the top of the barrel (no spigot on head).
I got lucky on my Mugello 225 as the std head sat inside the cylinder the same depth as the Avanti. Don't know if it's down to the central combustion chamber but it runs far better with the genuine Avanti head [and presumably cooler but I have no gauges to back that up].
Strummer10
Cheers Corrado......any idea if AF have tested to see what heat reductions this achieves ?
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
