TV175 1963 strip and rebuild
fluff34567 wrote:1 thing that I do need to mention and it's important! Here you are not allowed to fit any non original or "non authority approved" parts but saying that if it looks original ...... this is in relation to cylinder kits. Crank will never be seen again so i can fit anything.
Where are you then Fluff?
fluff34567
Switzerland, land of regulations.
I'd be tempted to simply buy a replacement TV crank and rebuild it back to standard as the weak taper of the TV crank does not seem to become a problem until you increase cc or performance considerably. If you fit a lighter than standard flywheel, this will also have a dramatic influence and reduce any chance of the crank's taper shearing off.
fluff34567
Hi Adam... yes that is also my initial thoughts also.. I sent a few emails and will wait for the responses.
warts
Main scooter: honda
Isn't the lightened flywheel modified then?
fluff34567
warts wrote:Isn't the lightened flywheel modified then?
It will never been seen and no one is going to take a flywheel off to check it.
garry inglis
buzzsolomoto has a 175 crank for £120 plus postage £300 to switzerland lol lol
Some of the German dealers have to be the best bet.
http://www.scooter-center.com/en/produc ... 5*1*1*1*16
cgt75b
Main scooter: lambretta
I got one from Turners Merseyside many years ago £60 still going strong!
Good luck.
storkfoot
Sadly, Turners are no more :-(
