Fitting parmakit
Standard Px gearing with a 22 tooth Costa clutch 28mm delorto phbh 60 mm Mazz crank Parmakit suited for a 57 stroke ( hence the question) sip road 2 I have the parts just stuck on the packing side of it don't want piston smashing into the head.
Before you say it Cosa not Costa
- Muttley McLadd
Why such low gearing?
any suggestions
which 125 g/box ? an early one or late one?
- Muttley McLadd
Mine ran stock 200 gearing with the short fourth with one of those SIP boxes. Mine's a 60 mil crank version. With a RHS RZ pipe thing, runs the same gearing, and is much nicer to ride.ducksta wrote:any suggestions
It has never felt over geared, even two up.
Late mickMorgan wrote:which 125 g/box ? an early one or late one?
Names not Mick ?
The late gearbox will give you 5.2:1 (or thereabouts). Quite short gearing for a "Torquey" engine, the P2 gearbox is more like 4.7:1
Maybe a longer rod would be a consideration as well ?
WhateverMorgan wrote:Names not Mick ?
