Fitting parmakit
ducksta
Standard Px gearing with a 22 tooth Costa clutch 28mm delorto phbh 60 mm Mazz crank Parmakit suited for a 57 stroke ( hence the question) sip road 2 I have the parts just stuck on the packing side of it don't want piston smashing into the head.
ducksta
Before you say it Cosa not Costa
Why such low gearing?
ducksta
any suggestions
Morgan
Main scooter: T5 Vespa Mk1
which 125 g/box ? an early one or late one?
ducksta wrote:any suggestions
Mine ran stock 200 gearing with the short fourth with one of those SIP boxes. Mine's a 60 mil crank version. With a RHS RZ pipe thing, runs the same gearing, and is much nicer to ride.
It has never felt over geared, even two up.
ducksta
Morgan wrote:which 125 g/box ? an early one or late one?
Late mick :lol:
Morgan
Names not Mick ?
The late gearbox will give you 5.2:1 (or thereabouts). Quite short gearing for a "Torquey" engine, the P2 gearbox is more like 4.7:1
Maybe a longer rod would be a consideration as well ?
ducksta
Morgan wrote:Names not Mick ?
Whatever
