Many thanks in advance
Trail Tech Vapor ----- Any good?
alanscottj
- Main scooter: Lambretta GP SS250 Casa
Had my SIP speedo for 3 years now and I think it is time for a change - thinking of getting one of the TrailTech Vapor ones - before I jump straight in I thought i would see what you guys think of them. Any issues I should be aware of? Will they run ok with Varitronic?
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
- jonashford
- Main scooter: Lambretta SX RB235
I had one it was good, but changed for the gamma tech which is far superior
alanscottj
Yes, I have had a look at them too - but the one would need is a little priceyjonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
alanscottj
Have you run it on the road yet?bazza3004 wrote:Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
- Toddy
- Main scooter: Lambretta Series 1
+1jonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
- jonashford
Quality stuff does costalanscottj wrote:Yes, I have had a look at them too - but the one would need is a little priceyjonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
alanscottj
jonashford wrote:Quality stuff does costalanscottj wrote:Yes, I have had a look at them too - but the one would need is a little priceyjonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
I do agree - I wish I could afford the RTSE but I'm sure the Vapor will do for now
Only for short distances to check it workedalanscottj wrote:Have you run it on the road yet?bazza3004 wrote:Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
