Trail Tech Vapor ----- Any good?
alanscottj
Had my SIP speedo for 3 years now and I think it is time for a change - thinking of getting one of the TrailTech Vapor ones - before I jump straight in I thought i would see what you guys think of them. Any issues I should be aware of? Will they run ok with Varitronic?
Many thanks in advance :D
bazza3004
Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
jonashford
I had one it was good, but changed for the gamma tech which is far superior
alanscottj
jonashford wrote:I had one it was good, but changed for the gamma tech which is far superior
Yes, I have had a look at them too - but the one would need is a little pricey :roll:
alanscottj
bazza3004 wrote:Hi cant answer your question reggarding varitronic but i have a vapor and while im still finishing thescoot i have the vapor up and running. Its easy to wire up and prob has more functions than i need tbh. I have a non battery gp so took me feed from the horn live. The set up instructions are easy to follow also.
Have you run it on the road yet?
+1
jonashford
Quality stuff does cost
alanscottj
I do agree - I wish I could afford the RTSE but I'm sure the Vapor will do for now :D
Hammy
Main scooter: lambretta ts1 225
Ive had a trail tech for 5 or 6 years now , changed the battery in the back of it 3 times , great bit of kit does everything i need .
bazza3004
Only for short distances to check it worked
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
