Two questions:
Is it possible to fit the later extended engine silent blocks to a series 2 engine in a SPANISH S2 ?
Has anyone manged to fit front suspension dampers to a SPANISH S2 whilst retaining the turning mudguard ?
Spanish series 2
- Toddy
- Main scooter: Lambretta Series 1
Yes and yesDaggs wrote:Two questions:
I fitted Dampers (BGM on Mine quite tight under the mudguard to get on and off but managed
- DigDug
As Toddy said.Daggs wrote:Two questions:
Spanish casings are no different when it comes to silent blocks.
And the dampers on the turning mudguard, yes me and Eibar managed it on the Winter TV2
They used the clamp on top brackets - Beedspeed do them although I can't see why you couldn't use the welded bracket.
Did you have to do that?
Got welded on brackets on both my eibars
Did you not find the mudguard holding brackets obstructed the weld on damper brackets ?
- DigDug
Even the clamp on ones take a bit of fiddling but it is possible.Daggs wrote:Did you not find the mudguard holding brackets obstructed the weld on damper brackets ?
Thanks to all for their input, I'll be giving it a go
