Stripped thread cylinder stud
vicvega
Main scooter: Scomadi
Looking for the best repair for the engine casing, has anybody tried these before
www.memfast.co.uk/shop/Vprod2.asp?cat=2250004326
Sorry couldn't paste picture, they're self tapping inserts, thinking might be stronger than helicoils?
not seen those before myself but they do look similar to the time sert thread repairs ,which are very good :)
vicvega
Cheers Sean, I'll give them a try.
gaz_powell
Never seen them before but they look good and at right price to have in, just in case.
I'm gonna get some M6 and M8
holty
Main scooter: lambretta gp
if its one of the barrel studs thats stripped, i would consider getting it welded up, then having it re-tapped, you will probably find that an insert will not be strong enough, also its hard to get a seal around the stud once repaired, i presume its a lambretta where there isnt much material around the stud hole to start off with, and not much gasket face either, a welded repair would be the best option.
holty :D
Chris in Margate
Still a little bit of meat below to drill and tap. Fit PX stud with loctite.
a.lo.v2
Main scooter: sx 200
looks like the hole needs to be bored to 11mm first, is there enough room?
Beedspeed and others do an oversize thread stud at one end I'd try one of those before I started drilling big holes
vicvega
Cheers, hedging my bets & have ordered both.
    Users browsing this forum: No registered users and 80 guests
