Fuel pump
smiffy1968
Main scooter: Nevermind Mk1 T5
I am about to fit a vacuum fuel pump for my 220 Malossi, running a heavily modified Si 24/24G carb. Anyone done this before?
Not on a standard carb,but you will need a bypass or the pressure will overcome the float needle and lead to flooding.
Ginch
Main scooter: Vespa 150 Super
smiffy1968
Thanks gents. I have a Mikuni pump with a 5mm bore pulse inlet. The hosetail i got from SiP is a Polini item with only a 3.7mm bore. I am thinking match the hosetail bore to the pump inlet size? Any experience or views greatly appreciated.
smiffy1968
Keihin flat slide carb now going on engine.
I'm heading the same way with mine, have spent hours trying to get it to run anything like right with an SI
smiffy1968
Had similar fun rosscla.
