RB25 on Indian GP200 box.
10 inch Terror
Xbox live gamer tag: No.
Hi all, does the RB25 go well with an Indian GP box? It's a Standard RB25 with 34mm Dellorto and NK Race pipe. AF recommend a final drive of 4.60. I have spare sprockets and chains so getting the optimum final drive should be easy. I have a Cyclone fitted at the moment but want to fit that into my RB20. What results are people getting? Any comments good and bad very welcome. Thanks in advance.
jonashford
Depends on a few factors, overall weight, exhaust and how u ride it. 4.6 might be ok if ur 11 stone no rally gear on the back and on the motorway, but hit a hill and it will most probably struggle. Id try it and see at least then u will know for yourself
holty
Main scooter: lambretta gp
ive had a gp200 gearbox in my rb250 and i worked fine, i have now gone back to an af close ratio box which uses the same 3rd and 4th gear as an indian gp200, just has a longer first gear, then a small jump to second and third, jump 3rd to 4th is same as the indian gp200 which is small anyway, i would recomend this setup helps to keep on the pipe, and kind to your clutch, sprocket sizes will depend on your riding style and weight, or ride 2 up.
holty
10 inch Terror
It'd be for a 12 stone rider mainly short blasts with the occasional longer run. I have plenty of front and rear sprocket and chains I can use. It's all about the final drive I suppose.
holty
probably down to the pipe, an nk race might be suited to higher gearing, try a 20 front sprocket and see if it will pull ok
:D
TS1-200
I have run GP200 gearboxes in my TS1`s over the years and found them very good with the added advantage that they tend to be easier on the clutch, go for 19 x 46 which equate to roughly 4.8, as said before depends on your weight, luggage carrying etc. 4.6 you may struggle a bit if you are 15 stone +luggage
Keep on keepin on
4.6 might be OK with the torque-based rally pipe, but with teh race pipe i would recommend 4.8 as the lowest option, 5.0 would pull better...and the race pipe has the revs to give the speed still.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
