self closing throttle
Adam_Winstone
Send me an email address and I'll forward you a couple of images that'll help you, which you may or may not choose to add to this thread...
adam.winstone@btinternet.com
Snails
Adam_Winstone wrote:Send me an email address and I'll forward you a couple of images that'll help you, which you may or may not choose to add to this thread...
Adam's photo in case anyone ever needs it
Snails
Now if I could only find a shop that sells split pins. Tried a B@Q megastore last evening but no joy..it would save a journey to a scooter shop, going to try hardware store on my lunch!
Adam_Winstone
Did you get the 2nd photo too?
Snails
Adam_Winstone wrote:Did you get the 2nd photo too?
No I dont think so
I set it up - it didnt return very much at all, so I thought 'maybe you need to wind it up a bit' which just resulted in the spring snapping. Very frustrating as I had to make up my SR order to meet the min postage requirements with spares I dont really need, I've had to go B&Q and Halfords on seperate trips to get the required drill bit and split pin and it didnt work so all in all its probably cost me £25 odd and now its snapped. Bloody scooters :shock: :oops: :shock: :evil: :roll: :lol:
Snails
Here's another photo from Adam Image
Is the idea that you tension the spring by compressing it down the length of its body?
Adam_Winstone
When you offer the assembly up you can feel how much you can pre-load the spring by turning the rod before fitting the throttle wheel. Whilst the photo of the standard Spanish headset shows the original split/rolled pin, I don't like the way that these (or the nylon rollers) go a bit slack once they've been fitted and used for a while, which is why you can see that I've tapped the rod holes and fitted mine with bolts.
When you're trying to figure out the preload for the spring, it should become obvious that too much will result in the spring becoming over-stressed or coil bound, which is not good, but a lesser amount will result in sufficient preload to ensure that the throttle closes itself when the grip is released but also allows the throttle to be used/turned as normal (not over stressed).
When you get to this stage, playing with the assembly should make it all become clear.
Adam
Snails
Adam_Winstone wrote:When you offer the assembly up you can feel how much you can pre-load the spring by turning the rod before fitting the throttle wheel.
Adam
From my memory of events its was not exactly wanting to spring back even without the wheel attached - even up to the point just before I snapped the spring. I'm wondering if there is not some other reasons its not working.
I guess an alternative, although more costly, solution would be fitting a quick action throttle.
Adam_Winstone
Determine why it is not working correctly. Effectively, this is a quick action/quick return assembly but something is stopping it from working. It would be a shame to introduce another throttle mechanism and then discover that you still have the sticking point (literally)!
I have this assembly on 3 of my scoots and they all snap shut (as required to participate in classic sprint meetings).
Adam
Snails
Yup, its fixed, simple as cleaning the powder coat off the throttle tube and applying a liberal amount of copper slip to all moving parts. Its not snapping closed but gently rolling back :)
Shame I spent all that cash on the spring ha ha and maybe goes to show how much stronger the spring is in my old jetex carb?
Anyway on to the next puzzle..where's my spark gone :(
    Users browsing this forum: Baidu [Spider] and 6 guests
