won't shift into second
Noplastic
Main scooter: Vespa PX221 disc
Hi all, im having problems selecting the second gear. when im in 1st and i try to shift into second either i hit a false neutral or it jumps straight into third. only if i keep pushing the gear change down somewhere between second and third it will engage but only for a second before it starts dragging and rattling and eventually shift back into the false neautral. i tryed all the possible cable adjustments but with no results. if i shift the gears manually from the selector arm or i walk the scooter with the engine off eevrythng seems to be ok. any ideas??
any help appreciated.
HxPaul
If your gearbox has been re-built,check that one or more of the loose gears have been fit on the layshaft the correct way around.
Noplastic
thanx for answering, i rebuilt it myself and im sure they are in the correct way around. i could spin the gearbox freely by hand, is this a typical sympthom of fitting gears wrong way round ? all other thee gears engage well...
garry inglis
when in second gear the selector arm should be paralell with the stood on the casing or in a straight line and is the selector on top the right way round and are the cables the wright way round from headset to the selector :?:
Noplastic
the picture is unclear :(
Noplastic
The arm is not aligning perfectly with the crankcase stud. Could this be the reason? Should I open the engine.
Noplastic
is probably about 75 percent not 90 degrees
fairspares
if the gear arm is not aligned correctly then it would only affect the selection of 1st or 4th gear , if you can post up a photo of the gear swivel / arm in 2nd or neutral .
gearbox wise, 4th goes in with the boss pointing towards you or side case then other gears with the raised boss pointing towards the rear hub.
ive just noticed you say its dragging and rattling more than likely you have either built gearbox wrong or the selector is mis-matching with the gearbox.
Noplastic
Noplastic
i took the pic with the mobile using tapatalk on the mobile is very clear , don t know from other devices
    Users browsing this forum: No registered users and 33 guests
