non runner
johnduke
Main scooter: lambretta series 2
Hi, well here goes i built my engine from bare case, spec is 175 iron cylinder scootopia 22 carb and clubman, sil electronic ignition . Ran great for 25 miles went home next day would not start ,good spark and petrol, hand over carb kick over and no suck . Rebuilt new seals started second kick ran great for another 20 mile run guess what will not run, no draw with hand over carb again ffs . Could seals have failed again so soon ?Out of ideas please help .
tarmac tickler
mate of mines seals kept going,, turns out his mag housing has been machined wrong and the hole aint in the middle, thus the bearing is off-set a bit ,,, does yours vibrate? his was undriveable,,
johnduke
Hi TT , no runs (when it runs) nicely ... how to did he check maghousing ? thanks john
Those seals would have had to have been shredded to cause it not to at least attempt to start. Had you tried bumping it? Also, did you check the rings whilst you had the barrel off? Otherwise, have you checked for spark/fuel flow etc?
Chris in Margate
LT coil on stator plate.
Daggs
My guess; You're putting the seals in the wrong way round.
johnduke
Hi , springs facing crank , also did leak test using inner tube spark plug was only obvious leak . Suspect seals as i say no draw at carb when turning over. John
johnduke
Hi, compression test was about 140 psi j
Chris in Margate
140psi perfect.
