Remade li150 gears
LI150
Main scooter: Series 2 LI150
Are these any good. I no there made in India so slightly concerned about quality. I plan on possibly using them with a Gt186 kit.
holty
Main scooter: lambretta gp
im pretty sure the sill ones are strong enough, i had a sil 200 gearbox in my rb250 for a while, no problems, only changed it for a close ratio,
holty
:D
Padge
Main scooter: 1969 Lambretta gp
I've used one in my brothers 193 that I built, he rags the nads off it everywhere and not had an issue with it
I plan on trying one in my TS1 230 i'm building
Tractorman
I must have got a bad set. First problem was second gear would not fit on the layshaft when I got it changed and the box assembled it was unbelievably noisy so I took the lot back and put the 125 gear set back in'
10 inch Terror
Xbox live gamer tag: No.
I don't think these 150 boxes are made by SIL. I've heard of shimming and fitment issues with them. I'd try and source an original Italian one if I were you.
LI150
Thank for replies. I have made my mind up I am not going to get one. Now to find an Italian one
HxPaul
Tractorman wrote:I must have got a bad set. First problem was second gear would not fit on the layshaft when I got it changed and the box assembled it was unbelievably noisy so I took the lot back and put the 125 gear set back in'
I fitted one and it was very noisy,I also had to run the cluster without a shim,with the shim fitted it locked solid.
