stage 4 200 and a 60mm stroke!!!!!!!!!!!
shamrockexpress
Is this a common set-up?????????mate has removed his ts1 its got a 60mm stroke can he put back his packer and put on the standard stage 4 200 sil set up,,,,,,,,,,,,,,,,,,,,would port timings squish be fine on the 60mm stroke?
thanx in advance
ps this is just a stop gap until his new GT200 kit arrives :D
Norrie Bodge
What thickness packer is it? 1 - 1.5mm ??
Your m8 not selling TS1 kit is he?
Bofs
It'll work fine. A 1mm Base packer will cancel out the extra stroke. It would need assembled to check the squish though.
Sent from my D5803 using Tapatalk
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Muppet
check transfer port height with packer
C’est la vie
Special X
It would increase the transfer and exhaust timing by aprox 5/6 degrees.
shamrockexpress
So an expansion would work better than the clubman????????
Have we finished talking about the 60mm stroke and packer?????????????????????
Moved straight onto,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,exhausts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You are going to change the gearing ?!?!?!?!?!?!?!?!?!?!
Mag
Main scooter: Carbon GP TS1
Can I join in?????????????????????
Muppet
check transfer heights with packer ask again; a adult mite reply
C’est la vie
shamrockexpress
Just passing the info onto a mate who asked my advice :roll: what would i know, i,m an electrican :D
will let yous all know how he gets on, first things first renewing his AA membership :D
    Users browsing this forum: No registered users and 28 guests
