Oil sight glass
jonboy
Main scooter: Vespa T 5 Classic
My oil sight glass is broken
Is it possible to renew without removing tank and replace
without removing the tank
Doubt it
Padge
Main scooter: 1969 Lambretta gp
tank has to come out I'm afraid. Easy job to do, disconnect fuel pipe from carb, remove grommets from sight glass and fuel tap, remove wires from fuel sender, undo 4 bolts holding tank and lift it out, lift rear first then pull back to get sight glass and fuel tap clear of frame....and bob's yer aunties live in lover
to refit is the same as removal, tip that might be helpful, I tie a 2 foot length of lockwire to the fuel tap and feed it through the hole in the frame before I start to help get tap back through the frame
jonboy
Is it best to drain fuel that's in tank or can it be left in
Padge
you can leave the fuel in if you want, easier if its empty (lighter) but you will need to drain the oil, just pull feed pipe off carb and drain into a drip tray or something
Chris in Margate
When I had a PX200 I broke that glass 3 times!
Get the fibre washer with the replacement; it doesn't come with it.
About a 20 minute job in all but you need a big open end spanner on it or pipe grips.
jonboy
I be already ordered the new one
but I have some fibre washers
maybe one will be same size
