Thanks for the link got one of those on the outer, my concern is with the circlip on the inside that holds the piston, washer and spring in as I don't want that popping out again and wrecking another 1st gear10 inch Terror wrote:http://www.lambrettaspares.com/spares/k ... 20scl.html
If you haven't already, fit one of these circlips.
gearbox/kickstart woes! :-(
ridden not hidden
Rs fruitbat
Use a 5mm drill bit for a standard M6x1mm thread
10 inch Terror
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
I used a 5.5 last week as I always do. I've never had one go wrong or have weak threads. Each to their own I guess.Rs fruitbat wrote:Use a 5mm drill bit for a standard M6x1mm thread
10 inch Terror
[/quote] Thanks for the link got one of those on the outer, my concern is with the circlip on the inside that holds the piston, washer and spring in as I don't want that popping out again and wrecking another 1st gear
[/quote]
Oh I see. Sorry I misread your question. I'd guess the circling wasn't sitting in its groove correctly, or the groove isn't machined deep enough perhaps? I'd refit it and just make sure it's seated correctly. If it seat correctly I can't see why it'd come out.
alanscottj
- Main scooter: Lambretta GP SS250 Casa
What's the close ratio box like mate? I've just fitted one tonight but Not had chance to go out on it
ridden not hidden
PM'ed you back misteralanscottj wrote:What's the close ratio box like mate? I've just fitted one tonight but Not had chance to go out on it
holty
- Main scooter: lambretta gp
if the circlip has fallen out before i would replace the shaft and circlip spring and dog just to be on the safe side, remember if parts are migrating around your gearbox they can jam the gears and lock the rear wheel, even break the casing, i would err on the side of do it right once, job done. i have done the same kickstart mod as shown above, allows fine adjustment of kickstart to get it to engage as soon as the pedal is pressed, highly recommended. if you do change the shaft, check you have clearance with your clutch top plate, some rub and need grinding a little so they dont touch.
ridden not hidden
My thoughts are the same holty, nothing wrong with the shaft, spring, circlip, washer etc but am replacing with a casa one as like you said it could happen again and will be doing the LI ramp modificationholty wrote:if the circlip has fallen out before i would replace the shaft and circlip spring and dog just to be on the safe side, remember if parts are migrating around your gearbox they can jam the gears and lock the rear wheel, even break the casing, i would err on the side of do it right once, job done. i have done the same kickstart mod as shown above, allows fine adjustment of kickstart to get it to engage as soon as the pedal is pressed, highly recommended. if you do change the shaft, check you have clearance with your clutch top plate, some rub and need grinding a little so they dont touch.
