End plate stud help required......
alanscottj
I have just had some ally welding done on a casing and the welder has drilled and tapped new holes for the studs. He has done a fantastic job (aircraft welder ;) ) but on one of the stud holes he has drilled and tapped it a couple of mm too deep, meaning that the stud goes in slightly too far not leaving a great deal of thread for a washer and nut.
Can I get a longer stud or is there any other option for me?
Also, do you guys use loctite on the studs?
Many thanks in advance :D
HxPaul
Just put a couple of small washers in the hole and screw the stud up to them.
alanscottj
HxPaul wrote:Just put a couple of small washers in the hole and screw the stud up to them.
That had crossed my mind actually :lol:
What about loctite?
garry inglis
hxpaul nice one :D
HxPaul
I always loctite all the engine studs in place.
wack 63
Main scooter: '71 GP TS1
Drop a ball bearing in.
10 inch Terror
Xbox live gamer tag: No.
Agree.
a.lo.v2
Main scooter: sx 200
in think MB do longer studs, or get some 7mm threaded bar or a bolt and cut it to length.
a.lo.v2
or exhaust stud?
alanscottj
Sorted! Nice one :D
Now, do I use flat washers or spring washers?
