Scoot RS Dics brake
Rick
Main scooter: Jet200
Has anyone a parts diagrame for a Scoots RS dics I can't find one anywhere... My dics was stripped by the chap spaying it and we think there are a few parts missing
You might find an exploded diagram of the Italian one. Wouldn't they be the same?
Inboard should be the same but Innocenti never made an outboard. :D
Rick
Sorry it's an outboard hydrolic brake
Long spacer tube in centre of hub, bearing either side of that and seal either side of each bearing. Axle goes through the caliper mounting plate then through the speedo housing cover, then small spacer tube goes on axle then feed axle through the hub, insert top hat over axle on the nearside then thick nut goes on.
bazza3004
Couldnt get mine on with the thick nut without levering link out. Swapped it for the standard half nut and alls good.
    Users browsing this forum: No registered users and 38 guests
