Scoot RS Dics brake
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
You might find an exploded diagram of the Italian one. Wouldn't they be the same?
- corrado
- Dealer
- Main scooter: Lambretta GP
Long spacer tube in centre of hub, bearing either side of that and seal either side of each bearing. Axle goes through the caliper mounting plate then through the speedo housing cover, then small spacer tube goes on axle then feed axle through the hub, insert top hat over axle on the nearside then thick nut goes on.
Couldnt get mine on with the thick nut without levering link out. Swapped it for the standard half nut and alls good.
