Scootopia 22mm carb set up
garry inglis
I didn't no there was a175 jet the hole will be like a1/4 inch pipe lol//////
115 is smaller than standard - more likely 125?
bristolmod
rosscla wrote:115 is smaller than standard - more likely 125?
concur!
Scootering since 1968.
Nerdy Norm
Main scooter: Lambretta LI 150 S3
I've got a Scootopia 22mm carb on an original LI 150 iron barrel, rebored by AF Rayspeed to 175cc, AFR 42mm Clubman exhaust and drilled original airbox (narrow neck).
My carb setup (as recommended by AFR, and seems to work OK):
200 slide
5899-2 atomiser
122 main
45 pilot
50 starter
Lambretta LI125 Series 2, Lambretta LI150 Series 3, Lambretta J100 Cento, LML Star 150 2T
Scootermonkey
Thanks for that, I'll give it a try .Been trying to ring A F Rayspeed but they don't answer the phone.
How hard can it be!
Lambretta, the finest scooter............IN THE WORLD!
Try just after 5
