Scootopia 22mm carb set up
Scootermonkey
Hope it's ok to post this here, seems to be read by more than on the carb page.
AF Rayspeed 175 top end, standard exhaust, and a Scootopia 22mm carb. I have a 150 atomiser and slide, and a 200 atomiser and slide as supplied with the carb. Anyone know the best combination of slide and jets to suit the 175 set up? Thanks
How hard can it be!
Lambretta, the finest scooter............IN THE WORLD!
200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
Tractorman
Doom Patrol wrote:200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
I struggle to understand jetting the recommended main jet for a standard GP 200 with a 22mm carb is 118. My 225 mugelo has a 25mm phbl and the main jet is 102, it's been set up on a dyno and runs well. Why is this?
Scootermonkey
Puzzles me too. GP150 main jet 118, same as a 200
Someone suggested a 122 main for the 175 set up. ??
How hard can it be!
You can't really compare the two. The jets on modern carbs seem massive by comparison and can't be interchanged with the original jetting. It's best to think of them as a different range altogether. You sort of start from scratch with the modern Dell'orto's with another set of rules.
my jettex runs a 135 main altho the atomiser has been modified to flow more mid range andits a indian 200 with scootrs pipe runs lovely :D
Tractorman
So will a scootopia carb with an 118 jet use more fuel on than a modern card with a smaller jet?
very unlikely
a.lo.v2
Main scooter: sx 200
it amazed me in the latest scootering when tuning a standard indian gp200 with an ancilloti and a 22mm carb ended up needing a 175 main jet!!
bristolmod
a.lo.v2 wrote:it amazed me in the latest scootering when tuning a standard indian gp200 with an ancilloti and a 22mm carb ended up needing a 175 main jet!!
a typo surely??? 115 more like it
Scootering since 1968.
