P2 Spaco Carb replacement
nsaints
2008 Austraian Import P2
I'd like to replace the Spaco autolube standard carb on the P2 with a genuine dellorto carb, which hopefully should eliminate a few issues with the P2
I have a Dellorto Si 24/24 G body which I know is for a T5. Ideally I need a 24/24 E which I don't have
Anyone with experience using the 24/24 G on a P2 - recipe for disaster/tears?
Spaco have been building the Si range under licence from Dellorto for years. Dellorto have not been making any in Italy for all that time. They were fitted as a standard equipment latterly by Piaggio.
It may be that the carb is worn out but any genuine Dellorto E or G carbs will be probably 10 years old now and you might just be inheriting others problems.
It might be worth replacing the carb with a new one to see if that solves your problems. What are they BTW?
nsaints
Yes you're correct. Could do with finding a NOS Dellorto 24/24 E rather than something potentially worn out.
Poor starting when cold, a mystery oil leak from the carb box. And worst smokes like someone old burning tyres when cold
Sent from my iPad using Tapatalk
nsaints
Oh and poor idling speed. As in revs are inconsistent
