Original cylinder rebored to 175 vs Rayspeed alloy 175 kit?
Nerdy Norm
Main scooter: Lambretta LI 150 S3
Thanks, I'll take a look when I get home. From memory, I'm pretty sure that they are bigger on the alloy kit.
Regarding the heads, I think they're different. The alloy kit came with its own head. The head supplied by Rayspeed when they did the 175 rebore is a genuine SIL 175 head.
Lambretta LI125 Series 2, Lambretta LI150 Series 3, Lambretta J100 Cento, LML Star 150 2T
Nerdy Norm
Well, I checked the heads, and they are in fact the same (or at least they come from the same mould - one is slightly rougher than the other).
However, my decision was made for me - the helicoil insert in one of the exhaust stud holes in the alloy cylinder just spins, so it's impossible to tighten up the exhaust. I'll get it fixed at some point, but for now the iron cylinder is fitted.
With a bit of luck, I'll get it fired up this evening.
EddieStone
I prefer cast iron. The cheaper alloy stuff is too hit and miss.
Nerdy Norm
Tightened it all up and it fired third kick last night :)
Just need to set the timing and check the carb and I'm good to go ...
