lam tv175 series 2
firekdp
coaster wrote:JIMS that posted on here a few months back with pics of an S2 rectier he'd uprated with a silicon full wave rectifier. It's for use with the 12volt rewire on the stator but it points the way as to what's possible
http://scooterotica.org/forum/viewtopic ... =rectifier
That would be the best way of doing it, bolt in a bridge rectifier in the place of the selenium one but you will only need two wires, as the original was only half wave.
lammydave
i have a battery type rectifier off a series 3, you are welcome to it if you want to give it a try.....
martin123
thanks i have 3 tv175 2 x series 2 and one series 3 , this is the first of the restorations series 2, the black plastic unit in the first pic i was told is for a 6 pole stator, my 2 series 2 are 4 pole 6 volt , which is the old units with the steel cover ,
martin123
ok if i was to do away completly with the old unit i s there a modern type to replace like on of these http://cgi.ebay.co.uk/Regulator-Rectifi ... 7C294%3A30
lammydave
martin123 wrote: my 2 series 2 are 4 pole 6 volt , which is the old units with the steel cover ,
that is the one i have....
martin123
ok if its the steel cover type, then yes please ,how much thanks ,do you know if the parts are still av for these original type regulators and rectifiers
lammydave
martin123 wrote:ok if its the steel cover type, then yes please ,how much thanks ,do you know if the parts are still av for these original type regulators and rectifiers
i am not aware of any parts being available for these.....
pm me your address, and i'll post it off to you.....
david
martin123
hi i think the one series 3 tv175 i have is a 12 volt,thanks
martin123
thanks dave your a top man, anytime you need any machining let me know, cheers
    Users browsing this forum: Semrush [Bot] and 18 guests
