Kickstarts stiff....
FREE tuning and maintenance info, plus links to our original tuning pages that started it all off.
S2CUF
So I've come out to my lammy tonight. Gone to kick it over to start. But it's really stiff... Almost like its in gear. (Can assure you it isn't). So obviously it won't start. I can't even kick it over properly it's that stiff. Any ideas??
garry inglis
get the back wheel up off ground and see if you can turn the wheel if not you are going to open her up
S2CUF
I can push her backwards and forwards. So I no its not in gear....
Daggs
Pull in the clutch, the kicky should push down with virtually no effort. If it does? The trouble is deeper in.
S2CUF
Yep. If I pull the clutch in. The pedal goes loose as anything. Effortless. But still very stiff otherwise.
bristolmod
:shock: it could be called "compression"............. :D
Scootering since 1968.
S2CUF
Bristol mod. Not sure why you always have to put divvy clever c**t comments on people's posts.... Or is it just mine. Either way. I'd love to meet up...
mick1
Main scooter: Li Avanti 225
Front sprocket bolt may have worked loose and be catching on the side casing.
Also.....whip the plug out and give it a try.......i'd take the flywheel cover off and check everythings ok on that side.
last resort....side casing off
bristolmod
S2CUF wrote:Bristol mod. Not sure why you always have to put divvy clever c**t comments on people's posts.... Or is it just mine. Either way. I'd love to meet up...
sorry- what is your problem? You are apparently new to scootering and it may well be you are not used to the "feel" of a Lambretta on kick over.
I won't bother offering any further advise to you if you feel that way.
If you look back on my posts you will see that I don't put "divvy clever **** comments" but try to help.
And why should I wish to meet up with you?
cgt75b
Main scooter: lambretta
Nobody likes a smart arse, give over!!!!!!!! It's a fair comment.
