Series 2 rear light
Nerdy Norm
Main scooter: Lambretta LI 150 S3
Daft question - I'm refitting the rear light on my LI Series 2, and now I can't for the life of me work out what the support bar does. Although the light seems to be securely fitted, the bar is just loose inside the housing, rattling around on the bolts. I'm guessing that's not right!
Lambretta LI125 Series 2, Lambretta LI150 Series 3, Lambretta J100 Cento, LML Star 150 2T
HxPaul
The light fitting goes through the back mudguard and then you fit the strengthening bar.
It's angled to sit across the light bolts go through and fasten the nuts
Nerdy Norm
So it acts as a clamp, on the inside of the wheel arch, with the nuts and washers tightened up directly onto it?
No wonder it's rattling around, mine is currently inside the light housing!
DigDug
Nerdy Norm wrote:So it acts as a clamp, on the inside of the wheel arch, with the nuts and washers tightened up directly onto it?
Yes... :D
Did you have to do that?
    Users browsing this forum: Baidu [Spider] and 6 guests
