Dip pulling off in first
Lamaddict
I noticed it on a few engines and it drives me mad. It's pulling away in first and the revs drop a bit. I once tried adjusting a slide but that didn't work. Once into 2nd etc it's fine. Set up at the minute is a GT186 (best smallframe Kit, IMO) 25 Dellorto and Clubman. Gearbox li125 16x46.
Chris in Margate
Carburation is probably too rich at full revs. Not noticeable in higher gears because engine load doesn't allow it to rev so high.
thackers
Check your spark plug gap.
Is it just as you twist the throttle , like its gonna stall or run out of petrol ?
Lamaddict
Yes it's worse when cold and it feels carb related. As I say, I noticed on a few scooters.
mick1
Main scooter: Li Avanti 225
are you using a lightened flywheel ?
Lamaddict
^ yes :oops: but it seems a carb adjustment would be possible but where and how? I did reduce the angle of a slide once but it didn't make any difference.
Those symptoms can be the airscrew causing it be lean or the pilot jet is to small
eden
I agree with shocky on this one. To test it try pulling away with choke on.
Lamaddict
Thanks all, I have a 50 pilot jet I'll try a 55.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 11 guests
