I've fitted the LTH to a few 36bhp RBs and TS1s.....not had any slippage or issues, fit and forget.10 inch Terror wrote:From what I've read the LTH is good for 25bhp as it comes. The AF Race is slightly higher and should be ok for 30bhp. I'm sure someone will correct me though.roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
LTH clutch.
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
jonboy
- Main scooter: Vespa T 5 Classic
Can I ask which gearbox oil you are usingdrunkmunkey6969 wrote:I've fitted the LTH to a few 36bhp RBs and TS1s.....not had any slippage or issues, fit and forget.10 inch Terror wrote:From what I've read the LTH is good for 25bhp as it comes. The AF Race is slightly higher and should be ok for 30bhp. I'm sure someone will correct me though.roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
- drunkmunkey6969
- Moderator
Maximajonboy wrote:Can I ask which gearbox oil you are using
10 inch Terror
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
ldrunkmunkey6969 wrote:Maximajonboy wrote:Can I ask which gearbox oil you are using
Ditto.
ive rode a 44 bhp Lambretta with one that slipped its tits off in every gear all the time if you gave it a fist full.drunkmunkey6969 wrote:I've fitted the LTH to a few 36bhp RBs and TS1s.....not had any slippage or issues, fit and forget.10 inch Terror wrote:From what I've read the LTH is good for 25bhp as it comes. The AF Race is slightly higher and should be ok for 30bhp. I'm sure someone will correct me though.roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
10 inch Terror
I'm finding it a bit stiff to be honest. MB cable routed correctly and a yam lever fitted. Did anyone find the LTH a bit stiff at 1st and it loosened off after a few miles?
- DigDug
As the man said....drunkmunkey6969 wrote:I've fitted the LTH to a few 36bhp RBs and TS1s.....not had any slippage or issues, fit and forget.10 inch Terror wrote:From what I've read the LTH is good for 25bhp as it comes. The AF Race is slightly higher and should be ok for 30bhp. I'm sure someone will correct me though.roadrunnerian wrote:will a lth or a/f road be ok for a 30 bhp engine thanks
Did you have to do that?
the one I fitted wasn't stiff and didn't change over the 1000+ miles I did on it.10 inch Terror wrote:I'm finding it a bit stiff to be honest. MB cable routed correctly and a yam lever fitted. Did anyone find the LTH a bit stiff at 1st and it loosened off after a few miles?
gerryjunior
- Xbox live gamer tag: no
- Playstation gamer tag: no
- Main scooter: lambretta li 2
my clutch was stiff at first, its gotten softer after 1500 miles,
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
