Christmas tree bearing track
boxofbits
The case harding has gone on the Christmas tree knackering the bearing and the track seems to have had a bit of wear is there a tool to get this thing out?
wack 63
Main scooter: '71 GP TS1
Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
Grumpy225
Blind bearing puller and a little heat. Comes right out.
Muppet
wack 63 wrote:Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
+1
C’est la vie
I found the repair to be more expensive than the cost of a second hand cluster
Replacement track is about a tenner and the machining cost me 15£
boxofbits
Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Grumpy225
boxofbits wrote:Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Yes and there is a washer behind the race. Don't loose it.
If I have time this week I'll try to youtube a video of it.
jason frost
Or weld a nut in to it and use a bolt to pull it put
boxofbits
Got it with a puller easy I didn't pay a tension to how far the old one was in does it need to be flush got the new race in but it sticks out about 1.5 mm
    Users browsing this forum: Baidu [Spider], Google [Bot] and 8 guests
