Christmas tree bearing track
boxofbits
The case harding has gone on the Christmas tree knackering the bearing and the track seems to have had a bit of wear is there a tool to get this thing out?
Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
Grumpy225
Blind bearing puller and a little heat. Comes right out.
Muppet
wack 63 wrote:Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
+1
C’est la vie
I found the repair to be more expensive than the cost of a second hand cluster
Replacement track is about a tenner and the machining cost me 15£
boxofbits
Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Grumpy225
boxofbits wrote:Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Yes and there is a washer behind the race. Don't loose it.
If I have time this week I'll try to youtube a video of it.
jason frost
Or weld a nut in to it and use a bolt to pull it put
boxofbits
Got it with a puller easy I didn't pay a tension to how far the old one was in does it need to be flush got the new race in but it sticks out about 1.5 mm
