Flywheel on the move
Den 08
Main scooter: lambretta Gp 225
just wondering if is this normal, just fitted an m-tech, set at 25degrees retards back to about
17ish at about 7500 all looks ok with the strobe, not really sure if the jetting will need looking at yet
haven't been out on it, but whilst strobing at high revs I noticed that the flywheel seems to move out from mag
housing by a couple of mm is this centrifugal force in action or will this be something else!
when stopped there doesn't seem to be any play in bearings.
any thoughts please
bristolmod
1) Flywheel loose on crank- try lapping in / tightening nut
2) Flywheel AND crank moving towards mag side- front sprocket bolt loose/ not torqued down correctly??
Sorry- clutching at straws here- what ever it is it needs stripping down and investigating fairly urgently.
Chris
Scootering since 1968.
Den 08
bristolmod wrote:1) Flywheel loose on crank- try lapping in / tightening nut
Chris
I was thinking the same Chris haven't had it apart for a few years, was kidding myself that It might be normal :roll:
oh well spanners at the ready
bristolmod
.........or do what the rest of us do- Ignore it and it'll go away! :D
mick1
Main scooter: Li Avanti 225
Could be an optical illusion....
regards your setting with the M-Tech. I'd be careful with your setting unless your racing. If your "cruising" then you may be under 6000 revs and your timing could be nearer 20.....possibly too far advanced. I have an M-Tech and use setting 5. The timing is set at 22/23 degrees and should go back to under 16 degree at 8k revs.
Den 08
mick1 wrote:Could be an optical illusion....
Tbh I haven't looked at the settings in the box just slapped it on like you do :lol: will be doing a more thorough check tonight before I attempt to use on the road, I did think where am I going to be running around @7500 rpms probably once in a blue moon, as you said, in truth I will be around the 4500 to 6500 most of the time, but the flywheel thing threw me a bit,
bristolmod wrote:.........or do what the rest of us do- Ignore it and it'll go away! :D
I did kind of think that but then me sensible head kicked in :D
IanGP
Main scooter: GP 225 TS1
Ignore it until something falls off, then fix the bit that broke.
On a serious note, crank shouldn't have any sideways movement, could be loose oil seal retaining plate and bearing spinning in casing, every time you Rev the engine the cushdrive spring is pushing the crank sideways?.....whatever it needs to come apart.
Ian
