BRETTA WON'T START WHEN NOT STARTED A FEW DAYS
Chris in Margate
- Main scooter: Lambretta 1964 225 Special
Yes I agree with what Wack says but I can start my scooter after a couple of weeks ( more like days in truth as I use it a lot) without issue 2nd kick every time and I mix my oil just like everybody else.
Definitely fuel related. Check flow from fuel tap into a bottle. Check carb filter. Remove any inline fuel filters if fitted. Check float assembly to ensure it is free to allow fuel to flow.
- coaster
You didn't come back on my comment above, it's surprising how many people wring the throttle whilst kicking it over which just results in a weak mixture. Try it with the throttle firmly closed for a few kicks and see if it's any better.coaster wrote:Always keep the throttle closed when kicking it over, especially from cold. You'll find it fires up much easier.
Chris in Margate
Aha. Filter !
Let us know the outcome. (Keep that throttle shut!!)
Chris in Margate
So what was the outcome as I see you're riding it albeit with a few problems.
