BRETTA WON'T START WHEN NOT STARTED A FEW DAYS
idc23
Main scooter: lambrettatv175 3
When she it starts it runs clean, just seems weird it starts after a few days, but leave it for a week or two it wont, i think what wack says might be true ?
Chris in Margate
Yes I agree with what Wack says but I can start my scooter after a couple of weeks ( more like days in truth as I use it a lot) without issue 2nd kick every time and I mix my oil just like everybody else.
Definitely fuel related. Check flow from fuel tap into a bottle. Check carb filter. Remove any inline fuel filters if fitted. Check float assembly to ensure it is free to allow fuel to flow.
idc23
Ok will bin inline filter, thanks ;)
coaster wrote:Always keep the throttle closed when kicking it over, especially from cold. You'll find it fires up much easier.
You didn't come back on my comment above, it's surprising how many people wring the throttle whilst kicking it over which just results in a weak mixture. Try it with the throttle firmly closed for a few kicks and see if it's any better.
Chris in Margate
Aha. Filter !
Let us know the outcome. (Keep that throttle shut!!)
idc23
Throttle shut, will remember that .
Chris in Margate
So what was the outcome as I see you're riding it albeit with a few problems.
idc23
Think it was down to me giving it throttle , seems to start a lot better with no throttle, just got the problem of revs hold up like it is weak from a fast run.
Thanks Ian
