twist and go front wheel
- Main scooter: Lambretta
Is it the same big disk as the other ScootRS wheels?
What's the issue with the valve positioning?
Couple of pics?
Couple of pics?
Reference the deep well on corrados brake if the wheel follows the norm for auto type rims the 10 inch skipperrim has a well alot deeper than a lambretta one even the AF, SIP type you can put a tyre on one almost by hand , were I get mine fitted he uses a plastic spatular type tyre lever with soap just slips on no problem
- coaster
I've got a Zip wheel on the front of my Jet and managed to get the tyre on (Sava Monsun) without any great drama just resting it on the waste bin and using a pair of tire irons with insulating tape to protect the paint. Used washing up liquid as a lubricant. A tyre with a heavier construction would be harder though.shocky wrote:Reference the deep well on corrados brake if the wheel follows the norm for auto type rims the 10 inch skipperrim has a well alot deeper than a lambretta one even the AF, SIP type you can put a tyre on one almost by hand , were I get mine fitted he uses a plastic spatular type tyre lever with soap just slips on no problem
Inflating was another matter though
- corrado
- Dealer
- Main scooter: Lambretta GP
No issue with valve position but the only valve I had was a Bridgeport one from Demon Tweeks and wasn't 100% it was a perfect fit, maybe the pull in ones are what's required but my tyre fitter doesn't have 90 degree ones.
- corrado
- Dealer
Yes Steve, I reckon this rim would be the same, it has, as you said, a much deeper well than the SIP ones [SIP ones being deeper than AF] so fitting tyres would no doubt be easy.shocky wrote:Reference the deep well on corrados brake if the wheel follows the norm for auto type rims the 10 inch skipperrim has a well alot deeper than a lambretta one even the AF, SIP type you can put a tyre on one almost by hand , were I get mine fitted he uses a plastic spatular type tyre lever with soap just slips on no problem
