I got a bit carried away!!!
DickieD
Main scooter: 1970 GP 200
I got a bit carried away / distracted, the question is can this still be used? The damage is only where the flywheel bearing inner collar sits, the part the oilseal sits is undamaged. What do you think? Anyone done this and still used without problems?
Image20150611_180304 by Paul Davies, on Flickr
Image20150611_180251 by Paul Davies, on Flickr
Grumpy225
You could get it welded and re-ground but at this point it would be cheaper to buy a replacement.
struth matey !!,you were for sure a bit heavy handed there lol...but no reason why it wouldnt still work as the seal surfaces are still intact and good .
DickieD
Yes I know Sean, teach me to talk and work at the same time :lol: It should be tight on the undamaged parts and maybe a bit of locktight to make sure.
What's the consequence of it coming loose or spinning?
Buy a puller £20ish and never have to use a grinder again ;)
B-Race Tuning
Main scooter: Lambro, GP.
I found similar in a Malossi 210 before now and had been running fine for years apparently so don't see why not.
DickieD
Cheers Simon I think I will give it a try and see how it goes.
Wack63 Iv'e always done it like this and never had a problem till now :shock: Have considered a puller but some are a waste of time where you get yours from?
Just Lambretta sell em or Sundar scooters on eBay.
DickieD
Cheers I will have a look 8-)
Shipleystevep
Someone posted a thread on here about that type of puller. I bought one in the strength of that and it's brilliant. Can't remember where from though :roll:
    Users browsing this forum: No registered users and 21 guests
