Lambretta Stand
Does anyone know who makes the Lambretta stand which fits in the hole where the standard stand fits,but has a lever fitted to lift the scooter? Its a neat bit of kit .
mr series 2
- registered user
- Main scooter: LI 150 Ser 2
- Contact:
I modified an old scissor jack if you weld an old 3/8 socket onto it you can use it with a ratchet works well and is cheap
mr series 2
- registered user
- Contact:
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
whilst I appreciate the adaption of an old scissor jack, I think I'm missing something.
The original Lambretta stand (I assume we are talking about the one that slots into the crankcase and allows you to raise the rear wheel off the ground), is small and works well- it also fits neatly into the tool roll in the tool box.
What does the scissor jack give you in addition?
Chris
Chris
Scootering since 1968.
your not on about a paddock stand r you?Jonn wrote:Does anyone know who makes the Lambretta stand which fits in the hole where the standard stand fits,but has a lever fitted to lift the scooter? Its a neat bit of kit .
C’est la vie
No not a paddock stand,but does the same job and thats what I need it for. It fits under the crankcase in the hole as the usual standard lambretta stand does.It has a lever attached to a small frame that lifts up the rear wheel.More stable than the standard stand.
mr series 2
- registered user
- Contact:
Just a good solid stand for use at home in the garagebristolmod wrote:whilst I appreciate the adaption of an old scissor jack, I think I'm missing something.
Chris
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google Adsense [Bot] and 3 guests
