Lambretta Stand
Jonn
Does anyone know who makes the Lambretta stand which fits in the hole where the standard stand fits,but has a lever fitted to lift the scooter? Its a neat bit of kit .
mr series 2
Main scooter: LI 150 Ser 2
I modified an old scissor jack if you weld an old 3/8 socket onto it you can use it with a ratchet works well and is cheapImage
mr series 2
bristolmod
whilst I appreciate the adaption of an old scissor jack, I think I'm missing something.
The original Lambretta stand (I assume we are talking about the one that slots into the crankcase and allows you to raise the rear wheel off the ground), is small and works well- it also fits neatly into the tool roll in the tool box.
What does the scissor jack give you in addition?
Chris
Scootering since 1968.
Muppet
Jonn wrote:Does anyone know who makes the Lambretta stand which fits in the hole where the standard stand fits,but has a lever fitted to lift the scooter? Its a neat bit of kit .
your not on about a paddock stand r you?
C’est la vie
Jonn
No not a paddock stand,but does the same job and thats what I need it for. It fits under the crankcase in the hole as the usual standard lambretta stand does.It has a lever attached to a small frame that lifts up the rear wheel.More stable than the standard stand.
mr series 2
bristolmod wrote:whilst I appreciate the adaption of an old scissor jack, I think I'm missing something.
Chris
Just a good solid stand for use at home in the garage
Timbo
This..
ktmh5
Main scooter: GP225 Mugello
Timbo wrote:This..
Jon Betts from JB Fabrications makes and sells these, he's on facebook.
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 11 guests
