Points! ! ! PLEASE HELP!
Supereibar
dapper wrote:First thing I'd check is that the flywheel hasn't moved on its taper. Check that the woodruff key is in good condition and that the flywheel is torqued up correctly. Remeber that altering your points gap can affect your timing too.
That is a good point. I placed a new woodruff key when I rebuilt the crank. It doesn't want to stick in place well. It mooves easily on its slot up and down but not sideways, just up and down when the flywheel isn't on it. Is that the problem you think? I had the crank rebuilt and the woodruff key is new, why would it do that?
bristolmod
no don't worry- I've got a Mrs Bristolmod already.
Just thought you were fixing me up with another!! :shock:
Scootering since 1968.
Supereibar
bristolmod wrote:no don't worry- I've got a Mrs Bristolmod already.
Well... you just need to ask. I can sort out a flame for an old mod like you in a heartbeat....
this one is the age of your TV...
