P200 Timing
ArmandTanzarian
Hello all,
What is the recommended timing for a p200 with a lightly tuned standard barrel? The original spec is 23 degrees but that was presumably set in the good old days of full-fat, man's petrol rather than the crap we get now.
fastfrog
19° less risk of pinging/seizing.....
Size matters!
gaz_powell
The 'A' mark corresponds to 23 degrees and the 'IT' mark corresponds to 18 degrees
I`ve ran on `IT`18 deg for years.
always relied on the casing and marks on geniune piaggio stators without fail
Not sure that can be said forthe glut of cheap ones available.
Norrie Bodge
Agree with Gaz IT mark 18degrees
Run it also with a NGK B8 or a B9 for hard motorway use
Daggs
Would that timing (18*) apply to a PX125 engine?
gaz_powell
px125/150 were originally set at 18 (IT) - in this good old days - I would nt have a clue what they are now what with the restrictions they come with a stock.
ArmandTanzarian
I measured everything very carefully, strobed it all up and concluded that the IT mark was pretty much spot on 18 degrees. I thought I'd better check as it's an old ducati flywheel and a BGM stator.
goldeneye
always ran my standard P200E"s on 23*, or the A mark, bog standard, even the exhaust (only a T5 4th gear fitted) never had a problem . mildly tuned , the HB200 I had on, ran that at 18, or the IT mark. as gaz says, wouldn't know now, , as they have a different ignition fitted these days, made by Kokosan I think, with 12 coils on the stator, and a rev limiter built in and suchlike.
Lamaddict
Always run it 23 standard/standardish scoots but jetted correctly, same on my Lambretta's.
    Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
