T5 classic
willow
Main scooter: t5classic
hi all could anyone tell me why myT5 classic choke will not pull out no more than 4 mill.it starts ok weather its a hot or a cold day.i assume this 4 mill is making no difference to the choke. so whats stopping this from pulling out. :?: any input would be great
wack 63
Main scooter: '71 GP TS1
Whip the carb box cover and air filter off then you can see what happens when you pull the choke out. Failing that it's tank out to check the outer cable is correctly sat in the tube.
willow
cheers ive check carb all is as it should be at that end of the cable...... pulling the choke is not moving anything at the carb end so i suspect like you say its behind the choke knob so its tank out time.now where did i put that hammer.
mick1
Main scooter: Li Avanti 225
try a bit of penetrating oil first......
willow
mick1 wrote:try a bit of penetrating oil first......
I've tried that...infact I even thought about getting mole grips on it and giving it a bit of how's ya father :) but thought better of it
.so like as been said I think the tank will have to come off
soulboy
whip the plunger out and give it a dam good clean ;)
    Users browsing this forum: Semrush [Bot] and 9 guests
