Barrel Base Sealing
thebassmasta
Main scooter: GP TS1 240
threebond 1104, exactly the same as yamabond
nelson pk
+1 For threebond. Fantastic stuff.
bristolmod
"Evostik"................yes true.
During my first ever "decoke" in 1968 (in which I only removed the head and didn't even think to do the exhaust port :shock: ), I must have dislodged the cylinder and damaged the base gasket.
Upon rebuilding and running the said machine I could feel "mixture~" being forced out of the joint before transfer to the upper cylinder. Being skint and not appreciating the intricacies of a Lambretta engine (not a lot has changed), I simply smeared a load of Evostik around the join area- seemed to work :D
Scootering since 1968.
thebassmasta
bristolmod wrote:"Evostik"................yes true.
shame its not heat resistent
nelson pk wrote:+1 For threebond. Fantastic stuff.
+2
